Generate digital pulse from Daqmx counter
I have set up a counter so that when i apply an impulse signal to it, it counts up by 1.
I would like to have it so that everytime it recieves an input impulse and counts up by one, i want it to generate a 'logic high' for a short period then go back to 'low'
How would i go about doing this? I want this counter to essentially be my clock and initiate events everytime a count is recieved.
Message 1 of 8
(4,242 Views)
So I don't understand. When some external clock generates a count you want your daq card to generate a count to something else? Why can't that something else use the clock that triggered the daq in the first place?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(4,217 Views)
I want to take reading from sensors every time I detect a digital edge.
If I wanted to do this how would I do it without using the counter? I want it to continously detect a digital positive edges, take a reading then wait until the next digital high edge.
Message 3 of 8
(4,168 Views)
You're looking for triggering.  But, why add the extra component?  Trigger your reading from the external line
Message 4 of 8
(4,151 Views)
Is it possible through labview to acquire a sample of the signal on a high edge trigger then stop at a low edge and repeat?
Message 5 of 8
(4,108 Views)
Accepted by mikeboxes
Hey mikeboxes,
Here's a old-but-good example of how to do what you're asking:
http://digital.ni.com/public.nsf/allkb/BA775B0E445BFA79482571FE0032CCEB
Tanner B.
Systems R&D Engineer - Aerospace, Defense, and Government
Message 6 of 8
(4,095 Views)
Depending on exactly what you need to do, you have gotten a couple good ideas. In addition, if your cards supports it, you can also generate an event on a digital transition that will trigger an event structure in LabVIEW.
I believe that you can also trigger and clock timed structures from external sources.
Mike...
LabVIEW Champion
Message 7 of 8
(4,085 Views)
ah yes, this is what I was looking for and is working for my application.
Thanks plenty!
Message 8 of 8
(4,065 Views)
