Generating 200kHz Sinusoidal AO USB6363
I am fairly new to labview. I have been trying to configure an analog output for sinusoidal signal generation at 200kHz for my application generating continuously for a user defined time. I can manage this for signals up to 100kHz sampling at 1Mhz, which works okay. When I try to increase this to 200kHz at various sampling frequencies, I get an error.
If I do a similar application of 200kHz in for finite duration (i.e. 10ms), It works. I am sure there is something silly that I am missing but I am yet to fix this issue. Any thoughts?
This specification of single channel AO generation is 2.86MSa/s which I am not exceeding. I do however notice, that if I go over 1.25MSa/S (the conditions for 4 AO used simultaneously) I also get an error, but I am only configuring and using 1 channel. Weird.
I have attached the VI example where it does not work.
(p.s. I have also tried removing the duration to stop the loop incase this is the issue, but no luck).
(1,129 Views)
Hi Jenks,
Your AO task is set to 400kHz samplerate.
Your SimulateSignal ExpressVI is set to create a waveform of samplerate 2MHz with a sine at 200kHz of just 10 samples. Later on you remove any waveform timing by converting into a 1D array of samples.
Which error do you get? Where does the error occur?
My recommendation: get all those numbers clear. I also recommend to create waveforms of more than just 10 samples…
(1,082 Views)
