Get XML String Without the Declaration
Is it possible to get the XML string from a DOM reference without the "<?xml ... ?>" node at the beginning? I'm having to manually remove the XML declaration using a Match Pattern function, which seems tedious and unnecessary. I'm guessing there is no way to do this, as the parser just does what it does. But perhaps there is a DOM property for this?
The attached example implements the following test code:
And gives the following result:
You can see that the intermediate result contains the XML declaration, which I then manually remove to get the output string equal to the input string.
Curiously, when you use Flatten to XML, the string does not contain the XML declaration.
_______________________________________________________________
"Computers are useless. They can only give you answers." - Pablo Picasso
(3,783 Views)
Accepted by topic author rwunderl
Not entirely sure. but maybe like this?
Do close the document ref though.
(3,768 Views)
Use the 1st Child property. 😉
Qestit Systems
Certified-LabVIEW-Developer
(3,762 Views)
Works like a champ!
Not immediately intuitive, but the solution is at least plainly within the XML API.
Thanks for the quick fix.
(3,706 Views)
