Get front panel position of the control strange behavior
Dear Andrej,
Good question! There is no obvious connection between splitters and panes (they both exist as mutually independent objects of the front panel object). What you can do however is to just use the Convert Pane to Panel Coordinates method of the panel in question.
Kind regards:
Andrew Valko
National Instruments Hungary
Message 11 of 12
(428 Views)
Hi Andrew,
it was my intention to use Convert Pane to Panel Coordinates at the start, but the root problem is that it has some wierd bugs as described in the first post.
Message 12 of 12
(413 Views)
