Getting Started with Modbus over RS485 (LabView)
Hello NI Community,
I was thinking about implementing Modbus on LabVIEW. I need your suggestions to start with.
I'm also hoping that if someone has already done it. What approach they adopted? (Can share block diagram or VI)
Message 1 of 25
(3,627 Views)
Hi Michael,
There are ready-to-use Modbus libraries on VIPM. They come with example VIs…
Message 2 of 25
(3,613 Views)
Use NI Modbus Library Toolkit for LabVIEW
Message 3 of 25
(3,588 Views)
I used the NI Modbus Library in VI Package Manager. In my case the code for creating a serial master and reading registers of devices looked like this:
Message 4 of 25
(3,532 Views)
Hello Stuart,
I was planning to work around it on LabVIEW RT or FPGA. Those VIs will work in beforementioned?
Message 5 of 25
(3,522 Views)
Never needed to do it on RT, but I'm pretty sure it will work the same. FPGA?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9GYSA0&l=en-US
Message 6 of 25
(3,517 Views)
Hi Michael,
On RT the Modbus libraries can work.
How do you want to access the Modbus messages on a FPGA? Which hardware do you plan to use?
Message 7 of 25
(3,501 Views)
@GerdW wrote:
Hi Michael,
Hello Gerd,
I'm planning to interface Servo Drive with my FPGA over a Modbus
Message 8 of 25
(3,437 Views)
Hi Michael,
Ok.
  • Which FPGA?
  • Which kind of Modbus connection (LAN, RS485)?
  • How should your FPGA connect to that Modbus connection?
  • Why do you even want to do that in the FPGA?
Message 9 of 25
(3,433 Views)
@GerdW wrote:
Hi Michael,
Ok.
  • Which FPGA?
Dear,
  • myRIO
  • RS485
  • USB to Serial Connector
  • Because I've to rotate a something which is time critical and requires accuracy aswell
Message 10 of 25
(3,429 Views)
