Getting Started with Modbus over RS485 (LabView)
@rolfk wrote:
@Michael_Smith wrote:
I mean what software programming scheme I should follow, If I implement this Hardware Hierarchy?
You really keep changing the specifications on a whim!
First you talk about controlling the Modbus directly from the FPGA on the myRIO because you are concerned about latency.
Suddenly you want to connect the Modbus to the PC instead. That is quite a fundamental change in specifications. And poses the additional question what you want to use the myRIO for.
Hello Rolf,
No no the plan had been this from start. I didn't know how to access it using LabVIEW but now what I've understand is that I can't access serial port in LabVIEW FPGA that way. I'm just looking for an efficient and can't figure out which way is best suited. I'm a beginner level developer. The block diagram is the hardware level interface which I've to follow.
Message 21 of 25
(1,316 Views)
Hello Rolf,
So please explain what you do hope to do with the FPGA on the myRIO, and in fact why you even would want to have the myRIO in the picture. To me, when looking at your schemata, it looks like it is just hanging on your PC for no good reason.
Rolf Kalbermatter  My Blog
Message 22 of 25
(1,299 Views)
Hello Rolf,
myRIO for the RT 😬. It's good, right?
Message 23 of 25
(1,271 Views)
Hi Michael,
Modbus over RS485 is not RT.
The ServoDrive should be able to handle the "RT" stuff on its own. (Better ServoDrives definitely can do this.)
The PC can do all the stuff you need to do (AFAIK from your descriptions).
You forgot to explain why you need the myRIO to do non-RT stuff - especially with an additional communication line between PC and myRIO added to the communication with your ServoDrive…
Message 24 of 25
(1,266 Views)
@GerdW wrote:
Hi Michael,
I will be using myRIO to get status of other sensors that will be used to monitor the operation of servo drive. I have limit switch and proximity sensors for a safety. The purpose is to stop motor at 350 degrees so that it don't go for second revolution.
Motor does have a brake but these limit Sw and proximity will work as additional brake incase the motor ones fail.
I am still stuck with getting started with communication.
Which is preferrable in your opinion Modbus or RS485?
Message 25 of 25
(1,204 Views)
