Getting Started with the DSC Module manual
I'm reading Getting Started with the DSC Manual. I have problem in section Deploying the Periodic I/O Server ,step 3. I can't see Monitor Variables. Please help me ,  I use windows7 LV2009
(4,081 Views)
LabVIEW 2009 removed the menu item "Tools»DSC Module»Monitor Variables". Please use "Tools->Distributed System Manager" to open Distributed System Manager instead.
(4,057 Views)
thank you very much...
(4,041 Views)
This was a known issue since 2008 is there a more recent version of the  Getting Started with LabVIEW DSC guide that would actually point to the correct menu?
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(3,779 Views)
This is known issue since 2008, Is there a more recent version of the Getting Started with LabVIEW DSC guide that has this part fixed?
(3,779 Views)
Here is the updated version of the manual: https://www.ni.com/docs/en-US/bundle/372946d/resource/372946d.pdf
I went to ni.com/manuals and looked for the Getting Started with LabVIEW DSC and found a more recent version that has the correct links. Unfortunately when searching via Google, the older version pops up first.
(3,772 Views)
Smiley Very HappyExcellent and timely find for my needs!  Thanks for posting.
(3,754 Views)
