Getting grey level value
Hi Everyone!
How am I going to get the value of grey level of each pixel from the bmp file in a look up table?, I already got my phase value so its just the grey level that i have to get.
The attachment is what i have done.
Greatly appreciate anyones help:)
Message 1 of 9
(5,067 Views)
If you have the same problem you might want to stick with the same post
http://forums.ni.com/t5/LabVIEW/Calculating-phase/m-p/2418936#M746679
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 2 of 9
(5,047 Views)
Hi again Enriquez,
I assume you want your look-up-table to be in u8 as there are only 256 greyscales to be.
Your input is u32 = 2^32 =256^4
Your desired output is u8 = 2^8 = 256^1
You could divide your input u32 array 3 times through 256 e.g. using a FOR loop, or you could cube root the u32 array directly, or use the "split number.vi" three times sequentially.
Message 3 of 9
(5,043 Views)
Hi alex!
I have made changes in my program, instead of getting my grey level according to my bmp file, i made a constant to make my lens bmp file.
I have attached my vi:)
Thanks a lot!
Message 4 of 9
(4,999 Views)
Hi Enriquez,
I guess I misunderstood your intention;
now I think I understand what you want to do:
Alex
Message 5 of 9
(4,983 Views)
Here I've attached my VI
Message 6 of 9
(4,934 Views)
Hi Enriquez,
wow, this is quite ... creative.
Obviously, you want to plot "phase" as a function of "grey level" e.g. y_phase value = f(x_greylevel).
For which row or column of the phase array and the corresponding greylevel array?
Maybe, for all rows/columns?
Alex
Message 7 of 9
(4,919 Views)
 I actually want all the rows of phase array corresponding to grey level array shown in the graph.
Thanks!
Message 8 of 9
(4,908 Views)
I think you're looking for somekind of distribution function
1# re-shape the 2d Arrays to 1d Arrays
So, if your 2d array has 50 rows x 50 columns your reshaped 1d array is supposed to have 1 row and 50*50=2500 columns
2# Build an 1d array of clusters with each cluster-element containing 1 greyscale and 1 phase value
Important: the greyscale array is to be the first cluster element!
3# Sort this 1d array of cluster with the "sort 1d array.vi";
this vi uses a stable sorting algorithm which maintains the relative order of phase values with equal greyscales
4# On the Frontpanel, change the greyscale indicator element in the 1d array of cluster element to a color constant
Now, you will have redundant values in the sorted 1d array of clusters which has the dimension 1 row x 2500 columns;
redundant values are indicated for example when i - (i+1) = 0 is TRUE.
Message 9 of 9
(4,892 Views)
