Getting only the odd rows of an array
I have an array 120(rows)x160(columns).
I'd like to filter this array so that i get only the odd rows and i want to get an array of 60x160 in the end.
How can i do this?
I tried with "delete from array" and "Array Subset" but they allow me to get only a consecutive portion of the array, while here i want odd(or even) rows.
Message 1 of 17
(7,811 Views)
Use a For loop with indexed input tunnel and a conditional output tunnel.
The condition terminal should be driven from a "Equal zero" that comes from the remainded terminal of a Quotient Remainder that divides the iteration terminal by "2".
If I got the row column thing wrong use a transpose on the array before it goes to the For loop.
I do not have LV available to check so forgive me if I got that wrong.
Ben
Message 2 of 17
(7,809 Views)
Like this?
And now how do i build the new array? (That's a Array Subset)
Message 3 of 17
(7,801 Views)
Accepted by GianmarcoSbarra
No need for the Array Subset and you should be autoindexing the input array.  Here is a less computationally intensive version.
Message 4 of 17
(7,778 Views)
Doesn't this take out Single elements rather than rows? Am i missing something?
Message 5 of 17
(7,769 Views)
Yes, you are missing something. On a 2D array input, it will take rows.
Instead of posting, just do the experiment! Probably faster.... 😄
Message 6 of 17
(7,761 Views)
Two days in a row that you solve my problems crossrulz, you're changeing the way i work with labview, thanks.
Message 7 of 17
(7,748 Views)
Yes much more simple than what I attempted to describe and besides my version would have returned the even rows not the odd.
Ben
Message 8 of 17
(7,728 Views)
Ben
Tim's code also returns the even rows, but it is easy to fix. 😄
(e.g. initialize with TRUE or tap before the NOT to the conditional terminal)
Message 9 of 17
(7,705 Views)
@altenbach wrote:
Ben
Depends on your definition of "even": Index is even or 2nd row (index=1) is even.  Mine with return the even indexes.  If that is wrong, just change the initialization to a TRUE.
Message 10 of 17
(7,701 Views)
