Graph Scaling
Hello there.
I was wondering if someone can point me to the right direction with this problem i am facing.
currently, my program read a device data and graph it on the chart.
it takes the date of the first data, the last data and 2 or 4 weeks ago.
i want to calculate the slope of the graph according to what days i want it.
right now, my x axis from days 143 to 177
on the graph, i change it from 150-170 for instant.
what can i do to get the value of the x axis from the chart?
i hope i am not confusing you with my discriptions.
Krispiekream
(4,574 Views)
i think this is the right direction?
i change x scale to 154 and 169.
how do i get all the data of the array from 154 to 169?
Message Edited by krispiekream on 10-07-2008 05:38 PM
Krispiekream
(4,547 Views)
Well, it looks like you have an xy graph and not a chart.
Graphs allow cursors, so one simple way would be to place two cursors and do a linear regression of the data in-between.
A very old example can be found here. See if this helps.
(4,530 Views)
no, that didnt helped much.
so everytime i change the scaling values of my x-axis,
i want the system to calculate the slope between those values.
i need to rearrange/cut my array so that he will take data from 150 to 170 for instant.
 lets say that i have 200 days worth of data.
from day 1 to day 200.
but because of errors in the system. i want to take only the good data.
after looking at all of them. i know that the data from 150 to 170 is good.
i want to use the scaling of 150 to 170 and find the slope of that.
currently, my program take the slope of day 1 to day 200.
Krispiekream
(4,528 Views)
Accepted by krispiekream
You can use basically the same code, but instead of the cursor positions, use the xmin and xmax. Shouldn't be much different.
(4,525 Views)
you are right as always. that example did helped.
i got one more question.i am working with events structure.
so when i change the xmin and xmax scale values of the graph. i want it to automatically do the slope.
right now, i click on a button to recalculate the slope and i really don't want to press any button.
i cant seems to find anyways to add the change of the xmin and xmax values into the event structure?
Krispiekream
(4,483 Views)
