Graph isn't update when Windows is minimezed
Dear All,
I'm using Labview 8.2.1.
I have program where data are displayed on Graph.
When I Minimize the Window, data fo the graph are not refresh.
Please see attached file.
Thanks for your help.
(3,062 Views)
Try changing the chart update mode from Scope to Strip Chart (Advanced > Update Mode). I believe this will prevent this from happening.
CLA
(3,049 Views)
I think Thoult is right. change to strip chart mode.When the VI is running right click and shange the mode.
(3,038 Views)
Dear All,
I have modify the Update mode, and When I set values for update mode "Strip—Shows" or "Sweep" the problem doesn't appear.
If I want to use "Scope" mode the problem appear. Does anybody know how to avoid this problem ?
I also try the program with LabView 2012 SP1, and the same problem appear.
I have modify the parameter of my computer Video card... but nothing change
Thanks all to have take time to reply.
Regards
(3,024 Views)
Accepted by __KB__
Hello __KB__,
Use the ForceRedraw method in order to refresh your graph :
Here the help of this method : Force Redraw Method
Jérémy C.
NI France
(2,994 Views)
Thanks for reply.
Yes It run with "force redraw" method Smiley Happy
Unfortunately this method doesn't exist in version LV 8.2.1.
Regards
(2,988 Views)
