Graph legend problem
Hello guys, forgive me, my english is not so good. But, i have a little problem.
I'm working in a project: I need to diplay some data in different graphs. Example:
I have the group 1: Datax-1, Datax-2, Datax-3;
And the group 2: Datay-1, Datay-2, Datay-3;
The elements of group 1 must to display in the same graph, but i can choose which data i want to display: datax-1 and datax-2, or only datax-2, etc. For this, I choose the data and I click in a buttom that show me the graphs with the element's legend. But I can do it anytimes. I will explain my problem by an example:
At first time i choose de element datax1 and datax2 and I click on the button. The graph will show with legends of element 1 and 2. But if I, in the next time, choose only the element 1 and push the buttom, the graph will appear, but with element 2 legend's too.
Can you understood? I dont wanna the element 2 legend's in this case, only the element 1 legend's.
Somebody can help me?????
(2,633 Views)
An example here
(2,620 Views)
you find below an example :
Plot 0 = Datax-1
Plot 1 = Datax-2
to make Plot 0 only visible : right click on Plot 1 deselect plot visible.
Best Regards.
(2,611 Views)
oh, thanks. but Can i do it from diagram?
(2,605 Views)
this is the diagram :
Could you please share your vi. to understand the problem
(2,598 Views)
Accepted by Guilherme_Ludwig
to disable the plot 1 programmaticaly :
Best Regards.
(2,589 Views)
Programmatically, you can control this using a property node for your graph.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(2,586 Views)
