Graphing derivative of a function + tangent line on same graph. 70% done, I need help :(
Hello Everyone !
I am using Labview 8.6 but the file is saved as labview 8.5.
I am almost done with this assignment but i cant figure out how to draw a tangent line on top of the graph with derivative of the function.
Can someone please help me ?
Thank you
Labview File:
Assignment scan:
Message 1 of 13
(5,841 Views)
No one knows ? 😕
Message 2 of 13
(5,811 Views)
Hi antek,
what are you looking for? Do you ask for mathematical background to your homework?
I cleaned up your VI a little bit...
Message 3 of 13
(5,801 Views)
Thank you i will take a look at it.
What i am trying to do is graph tangent line on the derivative graph.  I am also not sure how to implement tangent line equation into my VI.
Message 4 of 13
(5,795 Views)
I cant open the file because its 8.6, could you save it as 8.5 ? Thank you. Sorry for double post
Message 5 of 13
(5,786 Views)
Hi antek,
well, you wrote: "I am using Labview 8.6..."
But here it is attached in LV8.5...
Message 6 of 13
(5,782 Views)
Sorry for the confusion. I meant to say that i am using 8.6 in school and 8.5 at home.
Anyways, the simplified VI you did is not going to work for me since i need to be able to input formula.
Message 7 of 13
(5,769 Views)
Hi antek,
"since i need to be able to input formula"
Why do you need to? You have a precise duty with only one given formula - so you can "hardcode" it using LV functions. No need for formula node...
Message 8 of 13
(5,752 Views)
I guess you are right, but i still wanted that formula node so i can test different functions.
Anyways how do i get the tangent line and most importantly how do i display it on one graph with the derivative of the function ?
Thank you !
Message 9 of 13
(5,732 Views)
Accepted by antek
hello
here a solution of how to add Ct to C
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 10 of 13
(5,714 Views)
