Gray triangle on the top left corner of control type
I cannot recreate that effect too. Just looked through a few of my projects the triangle on type-definitions always is dark grey, not black - independent of strict or not strict.
@bbell: Forget about my first answer - I completely misunderstood your question. I thought you asked about the difference between cluster with and without a type def.
Just a vague guess: where do "Instrument Init" and "Acq Data " com from? Are these perhaps part of a library?
EDIT: Probably not - I just checked this myself, triangle is also grey.
Regards, Jens
Kudos are welcome...
Message 11 of 21
(1,598 Views)
In LV 2017  I tried;
Strict vs non-strict
System control
Arrangement in the cluster
Mixed data types
full icon image ve non complete icon
nest type defs
Still can not recreate that in LV 2017.
Ben
Message 12 of 21
(1,589 Views)
Here are the type defs attached. I believe they are saved in Labview 15.
Also, the gray one came with the template that I used for state machine. The black ones were clusters that u made into type defs by right clicking them and clicking "Make Type Def" or something to that effect. Maybe that could give some insight?
Message 13 of 21
(1,580 Views)
Thank you for sharing those!
In LV 2017 they are all the same black color.
The last guess I have at the moment is;
What version of LV were you working in?
Ben
Message 14 of 21
(1,572 Views)
I was using LV2013 until I migrated the code I was working on to LV2015. On both versions this gray issue came up.
Message 15 of 21
(1,569 Views)
Again thank you for that info.
I tried them in LV 2017 and LV 2015 and they were all the same color for me.
I will watch this thread to see if someone smarter than me can figure out the real answer.
Baffled,
Ben
Message 16 of 21
(1,568 Views)
Accepted by bbell
I found (the ???) difference:
A constant of the type def cluster in the block diagramm has a grey triangle, the terminal icon of a control or indicator from the front panel has a black triangle.
Nevertheless both controls/indicators and block diagramm constants should behave exactly the same when making changes to the type definition.
Regards, Jens
Message 17 of 21
(1,559 Views)
Regards, Jens
Nice catch there Jens !
You have one the "someone smarter than me " prize for today.
Ben
Message 18 of 21
(1,557 Views)
Regards, Jens
Actually, they don't behave the same if they are rings or combo boxes
Bill
CLD
(Mid-Level minion.)
Message 19 of 21
(1,543 Views)
Hi Bill,
Thank you for this insight! Do you think this is the reason some of my controls are updating and some aren't? Im using Menu Rings used for VISA Resource addresses. Would making them **indicator's rather than controls in the type def solve the issue?
bbell
Message 20 of 21
(1,538 Views)
