08-05-2010 03:58 AM
08-05-2010 07:07 AM
08-05-2010 07:33 AM
Same as this thread
08-05-2010 07:43 AM - edited 08-05-2010 07:45 AM
What is a "block"?
If you mean writing to a control or reading from an indicator, you would typically use a local variable.
(The suggestion above using value property nodes is not recommended in the typical case, because it is very inefficient).
