HTML tables have double-lines (they used to be single)
My predecessor made HTML reports that printed very nicely with tables that had single-lines.  Running this in LabVIEW 2018 (SP1 on Win7) gives me these hideous double-lines and I cannot stand it.
Here's a simple example:
Here's the code that made it:
I don't have any older versions to test if this is a version issue.  I don't know what our IT overlords have done to my computer so I can't say if it's an OS issue.  Have you seen this?  What do I do to create a table with simple, single lines?
Thank you,
Jim
Jim
Message 1 of 9
(4,003 Views)
This helps, but I'd be surprised to know it's needed.
Jim
Message 2 of 9
(3,980 Views)
Accepted by topic author jcarmody
Message 3 of 9
(3,975 Views)
With your code, I get the same look.  However you can embed a style tag into the report.
aputman
Message 4 of 9
(3,973 Views)
BTW, I tried in LabVIEW 2012. Doesn't seem to be a version difference.
aputman
Message 5 of 9
(3,968 Views)
Thanks, guys.  I went with the following because the text blew up, too):
Bonus points if you can tell me why it happened, and if this "fix" is likely to break the app on other operating systems.
Jim
Message 6 of 9
(3,945 Views)
Was there anything different about your predecessor's code compared to your post above?  I tried 3 different browsers and they all rendered the table the same.  Maybe your predecessor was using a separate style sheet that you just aren't aware of.
Is Arial available on other OSes?  I thought that was a Microsoft font.
aputman
Message 7 of 9
(3,933 Views)
No.  I changed from LabVIEW 2017 to 2018 and got here.
Jim
Message 8 of 9
(3,848 Views)
I added this to get rid of the silly header & footer...
Jim
Message 9 of 9
(3,835 Views)
