Have text field get focus in a pop over dialog
I am trying to get the attached dialog to
1. pop up over any other application that might be running, and
2. have the string control ("Combined scan of all 4 bar codes") get focus
In the VI I set the string control KeyFocus property to True.
If I click the run arrow from the dialog front panel, it works as expected.
If I click the run arrow from the dialog diagram, the OK button has focus. If TestStand calls the VI, the VI pops up but the title bar doesn't have focus. When I click on the title bar, the "OK" button has focus.
In the VI Properties->Window Appearance, I choose Custom over Dialog because Dialog does not bring the VI to the front when TestStand calls the VI. Here are my customized window appearance settings for the dialog:
(3,402 Views)
Found the issue.
the preferred execution system was 'user interface'. It needed to be standard, as it turned out.
(3,398 Views)
Accepted by topic author stephenb2
This is what I needed; I was unaware this existed: Making Dialog Boxes Modal to TestStand.
(3,293 Views)
