06-14-2017 11:56 AM
I am trying to get the attached dialog to
1. pop up over any other application that might be running, and
2. have the string control ("Combined scan of all 4 bar codes") get focus
In the VI I set the string control KeyFocus property to True.
If I click the run arrow from the dialog front panel, it works as expected.
If I click the run arrow from the dialog diagram, the OK button has focus. If TestStand calls the VI, the VI pops up but the title bar doesn't have focus. When I click on the title bar, the "OK" button has focus.
In the VI Properties->Window Appearance, I choose Custom over Dialog because Dialog does not bring the VI to the front when TestStand calls the VI. Here are my customized window appearance settings for the dialog:
Solved! Go to Solution.
06-14-2017 12:04 PM
Found the issue.
the preferred execution system was 'user interface'. It needed to be standard, as it turned out.
07-05-2017
02:17 PM
- last edited on
11-01-2024
03:31 PM
by
Content Cleaner
This is what I needed; I was unaware this existed: Making Dialog Boxes Modal to TestStand.
