Have trouble increment
    I have LED flashing and what to bit in a couter, to increment by one each time, do i need a loop? would like to do it for 10 second if possible
Message 1 of 16
(4,159 Views)
Hi gwhizz112,
you can use a LED with the blinking option or you use a loop.
Mike
Message Edited by MikeS81 on 06-17-2008 03:45 PM
Message 2 of 16
(4,153 Views)
Yes you will probably need a loop. Can you explain a bit more what it is that you are trying to do?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 16
(4,147 Views)
    i have a wave(like a sine) coming in on a graph and, when it goes by a certain point i what it to increment, and keep count how many time it goes by this point i have LED flash  when  thi happen but can not get to to count
Message 4 of 16
(4,137 Views)
Hi gwhizz112,
in this case you don´t need a loop, but without the loop i the no function for your LED. Smiley Happy
Mike
Message Edited by MikeS81 on 06-17-2008 04:21 PM
Message 5 of 16
(4,133 Views)
    sorry i am unable to find the pice in the picture can you please give me a hand
Message 6 of 16
(4,117 Views)
Hi gwhizz112,
one is "build waveform" and the other one is "get waveform components".
Mike
Message 7 of 16
(4,109 Views)
Which Labview version are you using?
Message 8 of 16
(4,101 Views)
    labview 8.5
Message 9 of 16
(4,098 Views)
Message Edited by smercurio_fc on 06-17-2008 10:56 AM
Message 10 of 16
(4,088 Views)
