Having several DAQ Assist.
Hello there.
I started by setting up one DAQ assistant supplying both "reading supply" but that made an error.
Then I started on doing this as shown in the VI (see attached file) - having one DAQ for each.
I simply want to supply two level sensors and read from them, so that i'm able to see whether the water level is high or low.
I really can't see what my problem should be, now that I have specified which output and input each DAQ should work with.
Are there someone who please can help me out?
Getting this for both "reading supply":
Error -50103 occurred at DAQmx Start Task.vi:9
NI Platform Services:  The specified resource is reserved. The operation could not be completed as specified.
Best Regards
Kenneth G. Vejen
Message 1 of 9
(4,014 Views)
You forgot to attach the vi. I guee the problem is with the Task configuration, how are you creating the task?
Message 2 of 9
(4,011 Views)
Ups, sorry 😉
Here it is..
Message 3 of 9
(4,002 Views)
Regarding the tasks.
I have created the tasks by "right click" on a block diagram, then "Express"-->"Input"-->"DAQ Assist".
From there I have configured the single DAQ.
Message 4 of 9
(3,999 Views)
As a search for the error code or the error message would have shown, you have a common beginner's error. You simply cannot have two separate DAQ Assistants. Create one for both analog outputs and one for both analog inputs.
Message 5 of 9
(3,983 Views)
I have actually tried that as well, but that does not work either, unfortunately!
But then I just get this error:
Write cannot be performed, because the number of channels in the data does not match the number of channels in the task.
When writing, supply data for all channels in the task. Alternatively, modify the task to contain the same number of channels as the data written.
Number of Channels in Task: 2
Number of Channels in Data: 1
There is probably something i'm missing, to make this code work, right? - see attached file.
Also I want to see bot measurements and have no idea how to do that. I have searched on the internet for hours, but no luck.
Message 6 of 9
(3,980 Views)
I have deleted my power supply now that I only need a constant 5V which an can get from USB-6008.
Then I have one last problem, how is it possible to read from both AI0 and AI1 from a single DAQ assist data-output?
See attached file.
-Kenneth
Message 7 of 9
(3,977 Views)
Accepted by kennethgv
If you want to control 2 analog outputs, you need to provide 2 analog sources. I think the error message is pretty clear. You only have a single control. Have 2 controls and create an array.
Your analog read does not make any sense either. You have a single comparison and a single (hidden) indicator. Why would you do that when you are trying to read 2 channels?
p.s. Creating an indicator and wiring it to the knob control is silly. Simply right click on the knob and select Visible Items>Digital Display.
Message 8 of 9
(3,976 Views)
I agree with you all the way and have simplified my code a lot.
I came up with this example instead.
Thank you for your time.
- Kenneth
Message 9 of 9
(3,973 Views)
