Help required in boolean pallette
I will acquire one pulsed signal through DAQ card in labview. Now what exactly I want is that whenever the pulse is High(+5v) it should give me True(Boolean Value) and when pulse is low(0v) it should give me False(Boolean Value).
How this could be done in LabVIEW?
Please Help.
(2,497 Views)
Please Help.
Sounds like you will be doing quite a bit more than just a T/F based on a voltage level.  You probably should be at least take the LabVIEW Introduction Course - Six Hours.
Bill
CLD
(Mid-Level minion.)
(2,477 Views)
Accepted by ArunBiom
Are you using a Digital Input or an Analog Input on your DAQ?
If the Digital Input, you should just have a boolean comming out.
If the Analog Input, then use the Greater? function with your read value to compare it to some threshold.  2.5V is a typical threshold for a TTL signal (5V).
(2,469 Views)
