Help with MODBUS over TCP
Hi all,
I have an emergency situation where I'm supposed to integrate an ADAM 6050 (Advantech) Ethernet enabled DIO device into our existing LABview based DAQ system.  It uses a Modbus over TCP protocol(s) to communcate.  I have never even cracked open a MODBUS manual, and I have only ttwo days to complete the project.  Luckily I only need to send one command to device.  Are ther any example programs out there or short tutorials that anyone would recommend?
Grub
Hell, there are no rules here...we're trying to accomplish something!!! - Thomas Edison
Message 1 of 8
(9,756 Views)
Download the modbus library from the NI site. Here is a sample modbus query from an ethernet device. 7.0 format
Message 2 of 8
(9,747 Views)
Thanks for the reply....I did download the MODBUS DLL that Labview published awhile back.  I tried using some of the code in there, but I couldn't get anything to work correctly.  I finally just used the TCP functions OPEN>WRITE>CLOSE, and wrote the commands that way.  It seems that sometimes the NI engineers get a little too clever with their VI's.  I'm sure they work great, but for somebody that doesn't know much about the protocol, its confusing to go through 5 levels of subvi's and multiple cases.
I'm going to read more about the protocol over the next few weeks and try to decipher what's going on in the NI VI's.
Thanks again,
Grub
Message 3 of 8
(9,740 Views)
Try this link. It is for 7.1 format files. I have 7.0 format at work.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=F1582737BACF5CA8E0340003BA7CCD71
Message 4 of 8
(9,730 Views)
Hey there unclebump. Could you please send me the 7.0 version of the library?
I'm really in need of that right now.
Thanks in advance,
Rafael.
Message 5 of 8
(9,506 Views)
Thanks unclebump, I got the library, and will try to use it.
best regards.
Message 7 of 8
(9,484 Views)
Grub!
Could you post your TCP vi for the 6050 module?
/Stefan
Message 8 of 8
(9,136 Views)
