Hexadecimal to Decimal Conversion
I would like to extract 040C from my frame and convert it to decimal. Currently, I’m able to extract it from the frame, but I can’t convert it to decimal. I tried using 'Hexadecimal String To Number', but without success.
DATA :       0112 080F 0000 1B58 0200 0004 0C02 0100 0100 00D0 3E
Does anyone have an idea, please?
Message 1 of 13
(1,138 Views)
Try this:
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 2 of 13
(1,101 Views)
forgot to attach the vi, here it is
Message 3 of 13
(1,102 Views)
for string controls you can view bytes as nonsense, byte strings, passwords? or Hex by right clicking the string control and selecting an option (see below).
Message 4 of 13
(1,099 Views)
Which is why you should make the display type visible if it isn't the default display type.
Bill
CLD
(Mid-Level minion.)
Message 5 of 13
(1,083 Views)
Yes ... if you look very closely you can see the "n" for nonsense ; )
Message 6 of 13
(1,020 Views)
Hi and thank you for your answers
I would like to extract 040C from my frame and convert it to decimal (040C = 1036). Your script extracts 4C from the frame (4C = 76). Maybe I didn’t express myself clearly.
Message 7 of 13
(1,001 Views)
I think you are missing a byte of data.
Bill
CLD
(Mid-Level minion.)
Message 8 of 13
(994 Views)
When I enter 040C as a constant, I’m able to convert it to decimal (040C = 1036):
but when I extract 040C from my frame (0112 080F 0000 1B58 0200 0004 0C02 0100 0100 00D0 3E), I don’t get the correct conversion (I get 0).
Message 9 of 13
(993 Views)
Accepted by topic author Fredo123Danzel
You have a binate string and this has nothing to do with hex formatting.
You need to typecast or unflatten it to your required datatype (U16 or I16). You get 1036 if you assume big endian.
Message 10 of 13
(976 Views)
