Unable to select option for ethernet port on PXI-8840
I'm trying to use a PXI-8840 as Ethercat Master for my project. But when I use NI MAX to configure the first ethernet port, I have no option in the droplist except "disable". Futhermore, I can't modify the configuration of the second ethernet port, there is no droplist available.
I've already tried the same manipulation on a PXI-8880 and it was working. I've installed exactly the same softwares on each target.
I've installed the driver NI-Industrial Communications for EtherCAT v23.5.0.49264-0+f14
Did someone already face this issue? How can I resolve it?
Regards
Julien
(369 Views)
Accepted by topic author gipsy64
I've resolved the issue thanks to the support. I've updated the firmware of the BIOS and downloaded again linux RT.
Julien
(270 Views)
