Homming Stepper Motor before Main Loop
I am building  2 axis drive using stepper motors. My code runs good in Arduino but I want to use Elvis and Labview, but I do not know how can I implement my arduino code to work same in Labview.
I want to do initialization (GO Home) before main loop starts.Here is My Code Example:
If(RUN PRESSED)
     if (HOME PRESSED)
           while (home_switch)
                   // Do this until the switch is activated
           while (!(home_switch))
                 // Do this until the switch is not activated
void loop()
   if (Button A Pressed)
         // Do this one Time
} //END MAIN LOOP
Any Help will highly be appreciated
Message 1 of 8
(3,052 Views)
If(RUN PRESSED)
     if (HOME PRESSED)
           while (home_switch)
void loop()
         // Do this one Time
} //END MAIN LOOP
Since your code works good in Arduino, why don't you post it?
I program in C/C++ for the Arduino Uno quite a bit. I'd like to see what you have done.
And why do you feel it necessary to use LabVIEW ?
Message 2 of 8
(3,029 Views)
I have NI-ELVIS II for data acquisition and I want to use labview for both motion and data acquisition.
Message 3 of 8
(3,019 Views)
So you have no Arduino code?
I figured it as such.
And you want someone to write the LabVIEW code for you, apparently.
Message 4 of 8
(3,010 Views)
I am not asking to write labview code for me. I have one question, If you want to answer Thanks, otherwise Many thanks.
Message 5 of 8
(3,005 Views)
But your 'question' is essentially, "how do you do one thing before another thing?"
I suggest you look at some of the training resources you can find at the top of the front page of the LabVIEW forum.
Message 6 of 8
(2,991 Views)
Of course, you were asking for the LabVIEW code to be written for you.
You provided no LabVIEW VI of your own.
You provided no Arduino code of your own.
You come empty-handed and expected "help".
Do some work of your own before you ask for "help"; otherwise, you are asking for code to be written for you for free.
Message 7 of 8
(2,978 Views)
He claims he has Arduino code. Yet has posted nothing.
That tells me he is not telling the truth.
Message 8 of 8
(2,977 Views)
