Horrible Behavior with Fuse Design (NXG) Style Numeric Indicators
With a Modern style numeric indicator, if it isn't wide enough, it truncates the right side.
But with a Fuse Design (NXG) style numeric indicator, if it isn't wide enough, it truncates the left side.
The actual value on both indicators is -6.43889
(1,040 Views)
missing image
Santhosh
Soliton Technologies
(1,015 Views)
@santo_13 wrote:
missing image
Lately when I attach files or include images, they disappear.  I'll try again tomorrow.
(1,011 Views)
NXG style numeric indicator justify to right by default.  Truncates left side is expected.
You can change it justify to left, then it will truncate right side.
George Zou
(1,006 Views)
Paul, I am not sure this is worse behavior.
There's critical information on both ends of the number:
-6.43889
+6.43889
11116.43889
-6.43889M
-6.43889E-19
-6.43889E+19
Now that you spotted it, is there any way to avoid the truncation?
Make the indicator wider.? Show less significant digits to make the number fit in the available width.?
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(948 Views)
