Host pc receive and send XML file to Crio
HI
I encounter a problem that is how do i send and receiveXML file.
I have LV project at my destop pc and there was a Crio device connect to the network,because my project is not under the Crio,it is under my computer,i  try to read the xml inside the Crio i used  'FTP' but can not access to Crio. Is there other way to read and send xml to Crio without a real FPGA project.
Message 1 of 11
(4,123 Views)
Hi pi number,
Is FTP enabled/installed on your cRIO?
Which cRIO? Which (LabVIEW) software version?
Is the cRIO accessable using a browser?
Yes sure, you can program some communication between a PC host and a cRIO target!
Is there a (LabVIEW) software running on your cRIO? Do you have access to the CRIO?
Message 2 of 11
(4,104 Views)
Hi GerdW
The Crio is 9074 and labview versin is 2016,i can access from browser
Because i am new to labveiw and do not know how to made this communicaiton to cRIO target!,do you have some sample VI?
Message 3 of 11
(4,099 Views)
Hi pi number,
Yes, I see from how you write the word LabVIEW… 😄
Did you notice that "Training" section in the header of this LabVIEW board?
LabVIEW comes with a huge library of example VIs and projects.
There are also example projects showing how to communicate from PC host to RT target!
Message 4 of 11
(4,096 Views)
Hi GerdW
Ok i will find some sample vi and test it
Message 5 of 11
(4,094 Views)
One other thing,because my project is seperater from the project which is ruuning at cRio target.
Is that also possible made the code to access to cRio target?
Message 6 of 11
(4,093 Views)
Hi pi number,
Having direct communication between PC host and RT target is (IMHO) simpler.
But you can also access the cRIO using FTP (for older cRIO, or after installing the FTP software package) or WebDAV (for recent cRIOs with actual software package)…
When you can access the cRIO using your browser then you can do the same with LabVIEW.
Message 7 of 11
(4,089 Views)
Hi GerdW
Yes can use FTP to access to cRio but in labview it can not work,i used the follow path
Message 8 of 11
(4,085 Views)
There are specific FTP VIs available under the "Data Communication -> Protocols -> FTP" Palette.
Message 9 of 11
(4,079 Views)
Accepted by 314159ym
Have a snippet. I'm feeling generous.
This was to FTP a file out of the RIO to local PC, modify some settings and FTP back to the CRIO. Then delete local copy.
Assumes RIO FTP is set up with username = Admin, Password = "" which I think is the default on the VXworks RIOS.
0xDEAD
Message 10 of 11
(4,076 Views)
