08-02-2011 11:01 PM
As the attached diagram, we have existing system, now need to upgrade with realtime data polling function.
Should I use solution 1 or 2. Any suggestion, thanks.
08-03-2011 01:27 AM
According to me you should follow the step 1
1. Real Time Server is directly connected with your Client application no database Server Required.
2. Database server you can use only in the condition of generating the Historical Trend or various reports.
3. Database server work independently to store your acquire the data.
Thanks and Regards
Himanshu Goyal
