How can I convert array of Boolean values to array of text
no sir it's not working and it is giving only three values in table and once you verify this sir with my VI
Message 21 of 25
(1,130 Views)
I checked its working as expected, please do try yourself by probing the values and fix.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 22 of 25
(1,122 Views)
i will upload my output file is it not giving the correct output sir
Message 23 of 25
(1,118 Views)
Hi kavya,
please attach your VI.
We cannot debug your frontpanel image nor do we see your block diagram…
Message 24 of 25
(1,115 Views)
I am so sorry sir it is working thank you so much GerdW
Message 25 of 25
(1,113 Views)
