How can I copy the file that download from NI package manager?
One of my two computers have installed so many large NI softwares and ultilities. Now the same files are expected to be installed in the other computer but the speed will be slow if download from Internet. Can I just copy the files downloaded through NI package manager to achieve the installation? If I can, what folders and files should I copy? where are they?
Thanks!
(3,140 Views)
They typically go into C:\National Instruments Downloads.
(3,105 Views)
Accepted by Heartnode
If Bob's suggestion doesn't work with NIPM, NI has a guide on installing NIPM and packages to an offline machine which may be applicable here.
(Honestly though the solution offered by NI is a terrible hack. I suspect you might be better off just downloading it all again).
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(3,099 Views)
