‎04-04-2022 07:06 AM
Merhaba, labview'de yeniyim. Ön paneli eklediğim VI'nın blok diyagram bağlantısı nasıl olmalı?
‎04-04-2022 07:25 AM
@aysınlab wrote:
Merhaba, labview'de yeniyim. Ö paneli eklediğim VI'nın blok diyagram bağlantısı nasıl olalı?
Hi, I'm new to labview. What should be the block diagram link of the VI to which I added the front panel?
That depends on what you want your program to do...
If you want to communicate in Turkish, post here: Türkçe Forum - NI Community
‎04-04-2022 07:30 AM
CTRL-E when you're on the front panel will bring up the block diagram, if that's what you're asking. If you have other questions please be more specific. Also, it would be a good idea to read through available training material and the LabVIEW User Manual.
‎04-04-2022 07:58 AM
My plan is as follows, how to set up the horizontal changeover switch servo, which button is shown when I press it.
‎04-04-2022 09:12 AM
What have you done and what problems are you having?
‎04-04-2022 09:19 AM
I set the front panel, but I don't know how to connect the desired function in the block diagram.
‎04-04-2022 10:20 AM - edited ‎04-04-2022 10:21 AM
Hi aysinlab,
Did you notice those training resources offered at the top of the LabVIEW board?
(Then you should know how to "connect the functions" in the block diagram!)
