How can I decode a data stream to jpeg image?
Norick, your input image is actually 8-bit depth. The labjpeg library has 24-bit depth. This is why you see the image 3 times smaller.
I've updated your vi to handle this issue.
cosmin
Message 11 of 31
(4,183 Views)
Accepted by Norick_17
I forgot to mention that I tend to use the .NET version in cases where I either use non-LV supported image types (gif,tiff, etc.) or when I want flexibility in the format.  In your case you know the format will be JPEG, so I would also try the platform independent method of using a temporary file.
No .NET, no DLLs, no need to know image size, yet still pretty fast on my machine.
Message 12 of 31
(4,174 Views)
@Darin
thats the solution I was looking for! As you mentioned no need of a dll and still have the full flexibility I wand - works perfect!
@Cosmin
also many thanks to your proposed solution which also works without problem now!
Thanks a lot again Smiley Very Happy
Message 13 of 31
(4,156 Views)
The VIs present in this thread are all except for one is on labview 2010.. i am using 2009 version, please can any one convert them to 2009 ?
Thanks.
Message 14 of 31
(4,096 Views)
can any body help me with labjpeg7.dll? what does it do ?
Message 15 of 31
(4,071 Views)
labjpeg dll is a library for handling jpeg strings, so you can visualize on the fly pictures sent by IP cameras or whatever.
It is a version of a library that I made some 2 years ago and I post it on:
https://decibel.ni.com/content/docs/DOC-13513
it has an example of using this dll in that link.
cosmin bucur
Message 16 of 31
(4,066 Views)
ok, thanks cosmin.
Message 17 of 31
(4,062 Views)
hay cosmin, one more help needed, i am not an advanced labview programmer, so i need to know some thing. Although i can use ur dll file to decode jpg image, but i want to make my own dll file just for the sake of learning, can u reffer any tutorial? also do i have to install LABWindows/CVI in order to make a dll for labview??
Message 18 of 31
(4,053 Views)
here i am again.. i have used the same VI as told by Darin..but i am getting a very disturbed image.. cane anybody HEEEELLLPP!!!???
Message 19 of 31
(4,014 Views)
Hard to do much without default data in your string control.
Message 20 of 31
(4,006 Views)
