11-07-2012 07:46 AM
Hi ALL,
I am very very new to LabVIEW and I just started to fiddle around with it. I am running LabVIEW 2010 SP1 version on Windows 7 OS. I also have NI PXIe-1073 chassis with PXIe-6361 and PXI-5105 modules and the chassis is connected to my PC via PCI. I was getting myself acquainted with the devices and was trying to see some analog signals to one of the channels on the PXI-5105 module in a graph in LabVIEW.
I would appreciate your helps.
Solved! Go to Solution.
11-09-2012
06:30 AM
- last edited on
10-13-2025
02:30 PM
by
Content Cleaner
Hello Henokview!
I would like you to read through these tutorials to understand the programming steps of NI-SCOPE and NI-DAQmx. After reading these links below you will be able to understand how to connect output from a readfunction to a graph or chart.
DAQmx
NI-SCOPE
http://www.ni.com/white-paper/3382/en
Best regards
Jonas
