How can I display the data in table in separate column?
I have a vi reading data one by one in the same column.
How can I display the data with separate column?
like this:
data 1 | read | read
data 2 | read | read
data 3 | read | read
(would you mind if I will ask for an example
because it is much easier for me to work
with an example)
THANK YOU.
(2,523 Views)
If you're reading your data in as a 1D array, this is as simple as using the Reshape Array to make a 2D array. I've attached an example in LabVIEW 6.1 format. The example rearranges a single column of data fill several columns horizontally, but you can easily modify this code to fill the columns downward instead.
(2,523 Views)
