How can I get a UTC timestamp?
Hi sorin,
@sorin1 wrote:
For example, if UTC date&time is March 26, 2020 16:50:04 (UTC), the value is 3668086204 seconds
Like this?
Message 11 of 19
(2,620 Views)
yes, but I need to get current date/time from PC (UTC, not local) and then converts it into seconds
Message 12 of 19
(2,616 Views)
Hi sorin,
Get current time from PC and subtract offset to UTC.
You get the offset by comparing the result of the timestamp to time cluster conversion with/without UTC flag or by using the %z formatcode when converting a timestamp to a string…
Message 13 of 19
(2,612 Views)
Then just use the Get Date/Time In Seconds and convert to a DBL.  The timestamp's data is in UTC.  The display will, by default, match the system format.
Message 14 of 19
(2,609 Views)
Please GerdW, could you post an example? thanks
Message 15 of 19
(2,608 Views)
Here's what I was saying.  The timestamp control shows the system time zone, but the data is still UTC.
Message 16 of 19
(2,601 Views)
I extracted the following solution from here
Regards
Vinay
Message 17 of 19
(2,532 Views)
Keeping your log files with UTC timestamp erases any DST ambiguities and other weirdness, like: what happens in the fall when you have two sets of data between 0100 and 0200, and in the spring when you will have a hole between 0200 and 0300?
Bill
CLD
(Mid-Level minion.)
Message 18 of 19
(2,509 Views)
The last system I did, I just kept the system on UTC (set time zone to UTC).  Much easier to manage then.  It also helped to synchronize with my UUT since it kept a UTC time.  I got really good at subtracting 4 or 5 hours in my head to convert to EDT or EST.
Message 19 of 19
(2,500 Views)
