10-08-2014 04:05 PM
The installation window in Windows 8.1 is too small to show buttons to agree to the license terms. I have tried to tab to the agree button but that doesn't work. Is there a way to make the window larger or to scale the information in the window?
Solved! Go to Solution.
10-08-2014 04:14 PM - edited 10-08-2014 04:16 PM
Are you sure you want to be using a graphics based programming language on a screen that is too small for an installation window?
LOL I'm guessing that that's just a small portion of the screen. Sorry.
It's like the fonts are too big. Try the DPI settings on your display options. You probably have it set to 125%?
10-08-2014 04:16 PM
aren't your windows dpi settings set to a large text size?
http://blogs.windows.com/bloggingwindows/2013/07/15/windows-8-1-dpi-scaling-enhancements/
10-08-2014 04:18 PM
I beat you by two minutes - but your post is more informative. 🙂
10-08-2014 04:18 PM
Screen is 1920x1080
10-08-2014 04:24 PM
No, I've tried I was at medium. Just changed to small (had to reboot the computer) and fixed the problem. Don't you just love windows 8!
10-08-2014 04:53 PM
It's not really Windows 8. I think it's been around for a while that if you have a large screen it will set the DPI to medium when the computer is first set up.
And isn't "medium" 125%?
And didn't you actually set the property discussed in the posts?
Unless you actually arrived at this solution without the help of the posts above, I actually think at least one of the other posts should be marked as a solution (and at least one be given kudos).
It's just a courtesy for giving credit where credit is due.
10-08-2014 05:25 PM
I had to reboot the computer to make the change take effect but you were right. dropped to 100% and it fixed the problem
10-08-2014 05:27 PM
You are absolutely right. I haven't had time to get on the forums for awhile and completely forgot my manners.
10-08-2014 08:00 PM
I thought I gave you a kudo but it was the wrong person - although that person definitely deserved it, too. ![]()
