How can I inslall LV 2014 in Windows 8.1
The installation window in Windows 8.1 is too small to show buttons to agree to the license terms. I have tried to tab to the agree button but that doesn't work. Is there a way to make the window larger or to scale the information in the window?
Message 1 of 12
(4,528 Views)
Are you sure you want to be using a graphics based programming language on a screen that is too small for an installation window?
LOL I'm guessing that that's just a small portion of the screen.  Sorry.
It's like the fonts are too big.  Try the DPI settings on your display options.  You probably have it set to 125%?
Bill
CLD
(Mid-Level minion.)
Message 2 of 12
(4,521 Views)
Accepted by topic author Warner
aren't your windows dpi settings set to a large text size?
http://blogs.windows.com/bloggingwindows/2013/07/15/windows-8-1-dpi-scaling-enhancements/
__________________
Engage! using LV2015
Message 3 of 12
(4,512 Views)
I beat you by two minutes - but your post is more informative.  🙂
Bill
CLD
(Mid-Level minion.)
Message 4 of 12
(4,507 Views)
Screen is 1920x1080
Message 5 of 12
(4,503 Views)
No, I've tried I was at medium. Just changed to small (had to reboot the computer) and fixed the problem. Don't you just love windows 8!
Message 6 of 12
(4,497 Views)
It's not really Windows 8.  I think it's been around for a while that if you have a large screen it will set the DPI to medium when the computer is first set up.
And isn't "medium" 125%?
And didn't you actually set the property discussed in the posts?
Unless you actually arrived at this solution without the help of the posts above, I actually think at least one of the other posts should be marked as a solution (and at least one be given kudos).
It's just a courtesy for giving credit where credit is due.
Bill
CLD
(Mid-Level minion.)
Message 7 of 12
(4,480 Views)
I had to reboot the computer to make the change take effect but you were right. dropped to 100% and it fixed the problem
Message 8 of 12
(4,473 Views)
You are absolutely right. I haven't had time to get on the forums for awhile and completely forgot my manners.
Message 9 of 12
(4,470 Views)
I thought I gave you a kudo but it was the wrong person - although that person definitely deserved it, too.  Smiley Embarassed
Bill
CLD
(Mid-Level minion.)
Message 10 of 12
(4,445 Views)
