04-08-2008 09:42 AM
Brian Beal wrote:
We are back to square one. I can't limit the editable area of the string control for my application.
Hi Brian,
the .net listbox option doesnot go with your requirement? Check the Message No.14 of the thread.
04-08-2008 09:43 AM
Ben wrote:
AND
You need to be able to type anywhere in the string control?
Ben
04-08-2008 09:47 AM
Hai Vsh,
Yes that worked well.
Mathan
04-08-2008 09:50 AM
Ben-
Yes, I need to able to type anywhere in the string control and have the listbox on top. I will look into the .NET control.
Brian
04-08-2008 09:59 AM
I'll give your req's some thought Brian.
Re: The .Net approach
".Net" solutions require extra work to make sure the targt machine has the proper version. Not that is a showstopper, just another thing to keep in mind.
Ben
