How can I read the table-color in a sub-vi??
How can I read the table-color in a sub-vi? Is it done by a reference to the table or with a global variable? For a better understanding of the problem I added to vi's. Please start the "run.vi". I wanna see
the same background color of the table in "run.vi" in the called sub-vi "read color.vi".
How can I do that?
thanks in advance
                        Norick
Message 1 of 8
(4,152 Views)
Hi Norick,
i can't open your vi at the moment. You can use the reference of the table to read the properties.
See the attched picture.
Mike
Message 2 of 8
(4,141 Views)
Hi
well I tried your suggestion but I do have the problem that I only read the background color of the selected index. Is it not possible to have access to all entries of the table at once?
In my opinion I should have access through the reference to all parameters like values,background color etc.
Please check my attached vi's for the problem.
thanks
     Norick
Message 3 of 8
(4,130 Views)
Hi Norick,
you can read everything at ones. You can resize the property node. Select what ever you want. The value property results in an array with all values.
Mike
Message 4 of 8
(4,127 Views)
Mike
with the values etc. it seems to work but I really struggle with the background colors of each index. Could you please check the vi's and put in the way you think it should work?
thanks in advance
                    Norick
Message 5 of 8
(4,115 Views)
Check the help on valid index values.
In adition to the cell indexes you would expect (0,0), (0,1), etc an index like (-1,0) will select a whole row (or collumn) and (-2,-2) selects the whole table.
Ben
Message 6 of 8
(4,110 Views)
Ben
the propertie with the background color reads the color of the current table. What I need is the color which comes along with the reference and afterwards I would like to
use this color to set it in the sub-vi.
Everything is working so far except the color...
Message 7 of 8
(4,091 Views)
Accepted by Norick_17
pop-up on the table refernece wire and do  "create control". Add this control to the icon connector of the sub-VI and then wire a ref from the calling VI to that terminal so the calling VI is passing the ref to the sub-VI.
Ben
Message 8 of 8
(4,086 Views)
