How can I save a graph in labview ?
@Eram wrote:
So where is destination folder defined  to save jpeg files?
You can specify a path using one of the inputs:
path to JPEG file specifies the path to and name of the JPEG file to write. If you do not specify a path, LabVIEW displays a file dialog box so the user can navigate to the file.
You can read more about the function here: http://zone.ni.com/reference/en-XX/help/371361H-01/lvpict/write_jpeg_file/
If someone helped you out, please select their post as the solution and/or give them Kudos!
Message 11 of 17
(1,096 Views)
Just an addon. Use an PNG for a better image format. Use a the function and connect the filepath
Message 12 of 17
(1,086 Views)
It is wherever you last went to with a file dialog.  I would recommend supplying a file path to the write VI.
Message 13 of 17
(1,083 Views)
I have a problem with it.
1- I want to save data from a graph in vector. how can i save this?i mean,i want to save image data during changing input. i think i need run save botton and end save botton.
thnx
Message 14 of 17
(1,009 Views)
In your save button, Try Mechanical action "switch until released"
Message 15 of 17
(999 Views)
thnx, how can i save my data(not graph) ?(e.g in excel file?)
thnx
Message 16 of 17
(995 Views)
Have you searched the forum? you will find loads of examples.  Post back if you are still finding it difficult
Message 17 of 17
(989 Views)
