How can I select a path to save the images from USB camera
I am Using USB camera for my senior project , I want to control this camera to detect a human body, using a motion sensor  and capture images.
my question is how can I select a path to save these images captured from USB camera ?
in the figure below , the program that I am using for my USB camera
thanks in advance ...
Message 1 of 23
(4,547 Views)
this is my VI
Message 2 of 23
(4,544 Views)
Hi duaa,
try this function to select a path...
Message 3 of 23
(4,535 Views)
This is another VI you would use to do the actual file-saving, called IMAQ Write File.
http://zone.ni.com/reference/en-XX/help/370281M-01/imaqvision/imaq_write_file_2/
Ravi A.
National Instruments | Applications Engineer
Message 4 of 23
(4,511 Views)
Thank you very much for your help
now I can select a path for saving the captured images
but the problem that i can save only 1 image and when it takes another one the first is replaced and deleted, so how can i save all the pictures without any replacements ?
Message 5 of 23
(4,496 Views)
Message 6 of 23
(4,495 Views)
You need to change the filename path on every iteration of  yoru while loop.
Message 7 of 23
(4,488 Views)
how can i do a while loop fot the path name ?
Message 8 of 23
(4,471 Views)
Use string functions to build together a filename with a value that changes, such as the value coming from the i node of the loop for the iteration terminal.
Then build that string filename together with the folder path to provide you with a file path that changes each loop iteration.
Message 9 of 23
(4,459 Views)
i have attached my program
i want the file name to change every time to be image1,image2,..
i dont know how to insert that loop to increment the path name
i have tried many trials and it didnt work
Message 10 of 23
(4,446 Views)
