How can I select a path to save the images from USB camera
Accepted by topic author duaa
Then move the snap subVI into the True case of the case structure.
Message 21 of 23
(704 Views)
i moved the snap into the true case of the case structure , but still i have the same problem i get images all the time
also i need to have a time delay between each image captured
could you please help me
Message 22 of 23
(688 Views)
How can you get images all the time if the snap is in the case structure?  It will only execute the snap VI when the condition is true.
Why the double while loop?
Message 23 of 23
(674 Views)
