How can I select a path to save the images from USB camera
Its pretty simple. Check this
Good luck
Message 11 of 23
(1,529 Views)
@duaa wrote:
i have attached my program
i want the file name to change every time to be image1,image2,..
i dont know how to insert that loop to increment the path name
i have tried many trials and it didnt work
Did you look at the snippet I posted at all?  What you tried looks nothing at all like what I posted.  Please try again.
Panand's example may work, but it looks a bit more convoluted than it needs to be.
Message 12 of 23
(1,522 Views)
Yes I have modified the user's code itself atleast he may look at that. I agree that your suggestion is the good way to go with compare with mine and I would go with that. 🙂
Message 13 of 23
(1,520 Views)
duaa,
P Anand and Ravens Fan have both provided solutions that work for your application; I'd definitely take a look at what they've coded. 🙂
Ravi A.
National Instruments | Applications Engineer
Message 14 of 23
(1,509 Views)
I have problem with capturing the images its only repeat the same image with different name
But I want each time to check the logic if its true to capture a new image ! If its false it will STOP .
Please I need your help ...
Message 15 of 23
(1,498 Views)
Please post the latest copy of your code.  It is difficult to understang what you are saying without code to visualize along with it.
Message 16 of 23
(1,488 Views)
Message 17 of 23
(1,480 Views)
Please review the example I posted on how to build the path to the file.  Right now, what you have is wrong.  You wind up with a path like "c:\images\.png0.png"
Message 18 of 23
(1,470 Views)
Also, right now you Snap outside of your logic, but you save inside the While loop. So this While loop is going to constantly save the same image over and over until you stop it. Then, it'll snap again, and then constantly save the same image over and over. If you want this to work, you need to put the Snap in the same loop as your save, so you have one Snap for each Save.
Ravi A.
Message 19 of 23
(1,455 Views)
i tried to iclude the snap in my loop and it works
but i need to stop snap images when my  case is FALSE
so what should i do ?
Message 20 of 23
(1,445 Views)
