How can I shift an image with vision info?
Hello
I am trying to shift an image which has been saved as .png with vision infos. This image I would like to shift by x/y pixels. If I do so I get a
blank image back, even I copied all the image infos in advance.
If I am using any other image without vision infos it works without problem so far. Does anybody knows how I can solve this problem?
Thanks in advance
(3,565 Views)
I'm having trouble reproducing the issue.  Can you also post the images you are testing with?
Alex Person
NI-RIO Product Support Engineer
(3,542 Views)
Hi Alex
I attached again the .vi and an example image.
         Norick
(3,523 Views)
Accepted by Norick_17
The IMAQ Shift function does not read any of the header information and is ignoring your reticule.  You can add the header information to the image by using the IMAQ Merge Overlay function as shown in my attached image and the IMAQ Shift function will actually see this data.
Alex Person
(3,513 Views)
That's it..!
       Thank you
(3,484 Views)
