‎07-31-2012 03:42 AM
I have vision inspection RT project with Labview RT and EVS , How can i generte a report ??
‎07-31-2012 04:58 AM
What kind of Report do you need? A LabVIEW RT Failure log or a Report of your Measurement Results?
Christian
‎07-31-2012 06:37 AM
Measurement Results in RT
‎07-31-2012 09:23 AM
Then it depends what kind of data it is and how you want to use this report later. Is it necessary to transfer the data to the Host and generate the report there, e.g. using the Report Generation Toolkit.
Or should it be a csv file located at the RT Target so that users can ftp it and analyze it individually?
Christian
‎08-01-2012 07:01 AM
OK , I have Basler camera connected to EVS RT with terminal Block and I have done inspection project real time it gives me Pass and different type of Fail
I want to analyze this results in a report in another PC, What can i do?
‎08-01-2012
07:30 AM
- last edited on
‎08-13-2024
02:07 PM
by
Content Cleaner
I would suggest you to use TDMS, which is descriped here. This link also contains examples and a link to download the Excel Plugin for TDMS.
Christian
‎08-08-2012 07:15 AM
Can you give me example how to use?
‎08-09-2012
02:01 AM
- last edited on
‎08-13-2024
02:07 PM
by
Content Cleaner
Christian
I just quote myself in case you stoped after the first sentence.
Christian
‎08-12-2012 04:33 AM
But i can not transfer the real time data "TDM" to the host
‎08-14-2012
06:21 AM
- last edited on
‎08-13-2024
02:08 PM
by
Content Cleaner
Frank,
With this last question, are you just looking for the best way to get the files from the Real-Time Target back to your host computer?
You can use FTP to do this in MAX: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIEiCAO&l=en-US
Best,
