04-08-2011 07:34 AM
I have a top level VI that calls a subVI, which calls a choice of a second VI. It works when I run the top VI. However, when I build the top level VI, it crashes on the first subVI. I have not yet learned how to build VI's. So, this is a newbie question. I see there are many options when building.
04-08-2011 07:36 AM
I am confused. ![]()
Can you post your code?
04-08-2011 07:56 AM
It works in the project folder as written. I have errors when I build the first VI. The second VI will have errors referencing a subVI.
04-08-2011 08:09 AM
First of al put wait in while loop.
And as I posted earlier, i did not get your question. What is error exactly?
I can see that you are running vis using "Open Vi Refnum" depending upon condition.
You also need to connect error clusters correctly to maintain dataflow.
