How do I create an embedded application and view the front panel on my host?
I have created a vi na dhave broken this down inot three components using RT comms wizard. How do I create the embedded VI part (exe) and then communicate with this via my host PC?
(2,794 Views)
Try building NPL***.vi into an exe while targeted. This will download NPL as an exe to the startup folder of your target. Now switch back to the host and build Host***.vi.
You'll have two exes - 1 for the target side and 1 for the host side.
(2,794 Views)
I can see you've done this before! This works a treat - I now have to look at building some batch files to deploy these.
thanks
(2,794 Views)
