11-30-2005 02:13 PM
11-30-2005 02:18 PM
11-30-2005 02:19 PM
04-13-2015 02:02 PM
For posterity, I found it useful to map the version number to the actual name of a Windows version. That information is here:
04-13-2015 02:29 PM
Or, use the Application property node Application>OS>Detailed Name. Although I can't say anything about its output on other-than-Windows OSes.
By the way, I think you win the "reviving old thread" award today ![]()
Dave
07-24-2017 12:26 PM
See attached VI. depending on your admin rights you might have to add command to run as admin. Tested on both Windows 10 and Windows 7 and works.
02-17-2022 04:21 AM
shrink down to this. due to lacalization of windows that change, for example, "system type" in "Tipo sistema: x64-based PC" in Italian.
btw it works. thanks.
