How do I find the first peak in a data set?
Hi
I was wondering how do i find the first peak of a data set?
Thank you
(2,796 Views)
Using a while loop, with the iteration connected to the index of your data set, check if the previous value (use a shift register) was bigger than the current. If so, then stop. The previous value was your first peak…
Ahum, hope tis is clear ..
Kind regards,
(2,787 Views)
Hi
Thanks for that.
I having trouble in getting it to  work. I will send what I have got so far.
Thanks.
(2,772 Views)
Try this.
Depending on what version of LV you have, you may be able to use the peak detect vi.
Hope this helps
(2,768 Views)
