How do I find the max and min value for each column of a 2d array?
For example in the attached array max/min for the first three columns would be 45/23,   14/10,   80/67.
Thank you
(4,644 Views)
Accepted by chuck72352
Chuck,
With the color on your bars, you should have enough experience to figure this out.  Smiley Wink
You are looping through the array already.  Now you just need a function like Array Max and Min. in the loop.  And perhaps you might need to Transpose the 2D array.
(4,642 Views)
Thank you. My solution is attached.
(4,633 Views)
Do not wire up both the N terminal and use auto-indexing.
(4,622 Views)
Done with suggested improvements.
Thank you.
(4,614 Views)
Your FOR loop on the bottom still has N wired while use the autoindexing.
Plus, are you sure you want your shift register uninitialized?  Your array will just keep growing. (I don't know how you plan to use this VI, so I'm just pointing it out as something to watch out for)
(4,593 Views)
